Stephen Dade > Jake RuebelAugust 27, 2015 at 1:58am
In that case you need the "APM1-tri", "APM2-tri", "PX4-tri" - depending on which APM board you are running.
Unfortunately you will have to do a bit of trawling to find the 3.1.5 stable version. Look at the "git-version.txt" in each folder for the version details.
Jake Ruebel > Thomas J Coyle IIIAugust 25, 2015 at 6:21pm
Thank you sir I had found that but the tricopter hex is not labeled or im unsure how to read the file system not sure how its organized
Stephen Dade > Jake RuebelAugust 26, 2015 at 1:43am
I'm not too sure what you mean by "tricopter hex" - do you mean a "Y6" configuration?
Each dated folder in aforementioned link contains a date/time of the build and then the build configuration.
@Jake,
Try here
TCII AVD
I'm not sure out of all those dates which ones are stable versions or are they all stable?http://www.rcgroups.com/forums/showatt.php?attachmentid=5401256&...
For example this folder: http://firmware.diydrones.com/Copter/2013-09/2013-09-06-12:09/PX4-y6/ contains the PX4 build for the Y6 copter, that was built on 6th September 2013. By looking at the "git-version.txt" it will tell you that it was the V3.1-dev version.
