I need to know how handle data from arduimu.
Hello to everybody.
I am an electronic engineer student and I am finishing my project with arduIMU+arduino.
For my project basically I need to send Picth, Roll and Yaw data from arduimu to arduino, but I have no idea about the way to handle the data that arduimu sent to, and how I can "extract" pitch, roll and yaw info from the serial data that arduino received.
My arduimu has been configured as this way (ASCII mode):
#define PRINT_DCM 0 //Will print the whole direction cosine matrix
#define PRINT_ANALOGS 0 //Will print the analog raw data
#define PRINT_EULER 1 //Will print the Euler angles Roll, Pitch and Yaw
#define PRINT_GPS 0 //Will print GPS data
Other question is I do not know the difference between ASCII or binary data.
Thanks for your support.
  • Change the user configurable options of ArduIMU V3 code as the one below:
    /*For debugging propurses*/
    #define PRINT_DEBUG 0 //Will print Debug messages
    #define PRINT_DCM 0//Will print the whole direction cosine matrix
    // *** NOTE!   To use ArduIMU with ArduPilot you must select binary output messages (change to 1 here)
    #define PRINT_BINARY 1 //Will print binary message and suppress ASCII messages (above)
    #define PERFORMANCE_REPORTING 0 //It's a message providing performances every XX seconds.
    #define MAGNETIC_DECLINATION 2.15 // magnetic declination in Rome. You' ve to change yourshttp://www.magnetic-declination.com
    Now upload the below code to your arduino:
    * @file IMUino.pde
    * @version 0.10beta
    * @author Francesco Cruciani, Francesco Vitullo
    * @note ArduIMU - Arduino binary serial communication
    * 15/02/2011 - www.codesigns.it
    // pin for serial input in arduino
    #define RX 0
    // serial rate for arduIMU
    #define IMU_SERIAL_RATE 38400
    // message tag
    #define IMU_TAG "DIYd"
    // number of messages send
    #define IMU_VALUES 3
    // union structure for serial received binary data
    typedef union{
    int16_t word;
    byte valByte[2];
    } IMUpacket;
    // intialization of the structures for each passed value
    IMUpacket serialPackets[IMU_VALUES];
    // first tag in message
    char imuTag[] = IMU_TAG;
    // first tag in message buffer
    char IMUtagBuffer[sizeof(imuTag)];
    // check for new data
    boolean newData = false;
    // vars for checksum
    byte msg_checksum_a;
    byte msg_checksum_b;
    // waits for n bytes to receive
    void wait_for_bytes(byte number){
    while(Serial.available() < number);
    // sums all the values and confront the result with the checksum passed
    boolean checksum_is_true(){
    byte current_msg_checksum_a = 0;
    byte current_msg_checksum_b = 0;
    for(uint8_t i=0; i<IMU_VALUES; i++){
    current_msg_checksum_a += serialPackets[i].valByte[0];
    current_msg_checksum_b += current_msg_checksum_a;
    current_msg_checksum_a += serialPackets[i].valByte[1];
    return (current_msg_checksum_a == msg_checksum_a && current_msg_checksum_b == msg_checksum_b);
    void setup(){
    Serial.begin(IMU_SERIAL_RATE);
    pinMode(RX, INPUT);
    void loop(){
    if(Serial.available()>0){
    // check if the byte is the start of new messange
    wait_for_bytes(1);
    IMUtagBuffer[0] = Serial.read(); // D
    if(IMUtagBuffer[0]==imuTag[0]){
    wait_for_bytes(3);
    IMUtagBuffer[1] = Serial.read(); // I
    IMUtagBuffer[2] = Serial.read(); // Y
    IMUtagBuffer[3] = Serial.read(); // d
    if(IMUtagBuffer[1]==imuTag[1] && IMUtagBuffer[2]==imuTag[2] && IMUtagBuffer[3]==imuTag[3]){
    // new messange
    newData = true;
    // receive all values and put it in the packet structure
    wait_for_bytes((IMU_VALUES*2)+2);
    serialPackets[0].valByte[0] = Serial.read();
    serialPackets[0].valByte[1] = Serial.read(); // roll
    serialPackets[1].valByte[0] = Serial.read();
    serialPackets[1].valByte[1] = Serial.read(); // pitch
    serialPackets[2].valByte[0] = Serial.read();
    serialPackets[2].valByte[1] = Serial.read(); // yaw
    msg_checksum_a = Serial.read();
    msg_checksum_b = Serial.read(); // checksum
    } else newData = false;
    // checksum for message
    if(newData && checksum_is_true()){
    // do stuff with received data values
    Serial.println(serialPackets[0].word/100);
    Serial.println(serialPackets[1].word/100);
    Serial.println(serialPackets[2].word/100);
    } else{
    msg_checksum_a = 0;
    msg_checksum_b = 0;
    Ensure that connection between ArduIMU and Arduino are as below:
    arduinoarduimu-300x161.jpgNow, connect the arduimu to  arduino like above and your arduino  to your PC and Open your Arduino IDE software. Go to Tools>>Serial Monitor
    It shall show the Pitch, Roll and Yaw data.
    Hope that was helpful.
    And I have a Question that: How can we power the ArduIMU without PC,ie., when on an RC Airplane or so.
    Magnetic Declination on Map
    Click on the map to find the magnetic declination at your location
  • Look into the parseInt() and parseFloat(); functions of arduino.
