I was connecting to the configurator now I am not
I was connecting to the configurator fine but had a problem with on of the motors, I fiddled with the pwr connector with the power on and I think I hosed things. I can no longer connect to the configuration program. Any one know if I can reset or fix this problem??
Thanks,Steve
  • Humm...on a quess I disconnected the Mag. and it connected. So it was related to the Mag.
    I still have a problem with the left motor, but I think its a faulty motor, I am checking that now.
    Thanks for everyones help....
    Check your CLI switch on the back right of the APM.  Make sure it's shifted forward (towards to the front of the APM) and then try reconnecting with the configurator.
    -Randy
  • Do you have xbees? If you do, enable the line in the code for xbee and then try connecting to the configurator that way.
