ibus support?
hi, does anyone know if Ardupilot supports flysky ibus protocol? I know Ardupilot supports PPM & PWM, but i'm just curious about ibus support. Thanks in advance.
  • http://www.skylarkfpv.com/store/index.php?route=product/product&amp...
    benbojangles said:
    I see there is a .hex file for APM2.6 boards to change the hex code on the atmel 32u2 to support sbus-to-ppm. I am wondering if there is anybody out there (RANDYYYYY!!!!!!! WHere are you!!!!?) who can tell me if a .hex file can be created to support ibus-to-ppm in the same way?
    What needs to be done to make this happen?
    -ibus signal data?
    Some data on ibus signal:
    Cleanflight code
    MultiWii code
    iBus to PPM converter with 10 channels PPM and S-Bus output
  • anyone got the C++ file for sbus-ppm converter?
  • there are two codes created to convert ibus-to-ppm already:
    1-here
    2-here
    Is it possible to simply compile these codes and flash to the atmel 32u2 chip?
    Bitbucket
  • I see there is a .hex file for APM2.6 boards to change the hex code on the atmel 32u2 to support sbus-to-ppm. I am wondering if there is anybody out there (RANDYYYYY!!!!!!! WHere are you!!!!?) who can tell me if a .hex file can be created to support ibus-to-ppm in the same way?
    -ibus signal data?
    Cleanflight code
    MultiWii code
Abdulatif Tlaib liked Ryan's profile
11 hours ago
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
