Inaccurate amperage display
I am using the following voltage and current sensor on my quad copter with APM 2.5 running firmware 3.0.1 because the DIY drones one does not support 6S setups:  http://www.rctimer.com/product_861.html
I have it connected as per the old wiki:  https://code.google.com/p/ardupilot-mega/wiki/Voltage
I have set the battery capacity in the MinimOSD to 5800mAh as I am using Zippy 6S 30C 5800mAh batteries.  I went for a flight this evening using a low voltage alarm on the battery set at 3.3V/cell.  According to the OSD, I depleted my battery to -3%, however according to my iCharger, I only put back 2322mA into the battery, or approximately 40%.
Can anyone help me figure out what such a discrepancy?
  • I imagine you need to play with the constants (VOLT_DIVIDER and AMP_PER_VOLT) to get the right voltage and current shown. The % figure shown in the OSD is the sum of current over time, so if the current shown is wrong, the mAh used will also be wrong.
  • Is there not anyone who can shed so light on this?
