Inaccurate velocity measurement of UBlox GPS
Hi All:
    During my ground tests, I found that the velocity measurement (in North-East-Down format) of UBlox GPS is not accurate as I expected. The experiment is like this:
    1. fix a UBlox GPS unit on a trolley, which is initially stationery;
    2. move the trolley forward with a relatively constant speed (about 1 m/s);
    3. Stop and check data.
    I found that the recorded velocity is liked a bounded but random signal, osillating in the range of -1~1 m/s (yes, I observed even the -1 value at some points). May I know that have you guys encounter a similar problem, and how did you solve it?
    If possible, can someone tell me how about the accuracy of the MediaTek GPS's velocity measurement. I roughly remember that it only gives course velocity. If so, based on the measured Euler angles, can I have the North-East-Down velocity vectors?
   Many thanks for the help and suggestions from all of you!!
Alex
    I think the uBlox firmware is optimized for much higher speed. Try again in a car.
  • No one has ever encountered the similar problem before!?
    Many thanks for sharing some experience!
