Hello everyone
I have searched hi and low trying to find out how to set up the inverted v-tail.
Pitch and yaw work well for the standard v-tail. But for the inverted v-tail if I get pitch to work I am unable to get yaw to work in the proper direction.
The air frame I am trying to config is the RMRC anaconda.
@Gregory,
I just completed setting up my Anaconda in the Manual mode.
Here is how I have it configured:
I setup the joystick throws according to the Wiki:
Ch 1: Roll left=low…Right=high
Ch 2: Pitch forward=low…Pitch back=high
Ch 3: Throttle down(off)=low…Throttle up=high
Ch 4: Yaw left=low…Yaw right=high
RCMAP_PITCH, 2 Left V-Tail servo
RCMAP_ROLL, 1
RCMAP_THROTTLE, 3
RCMAP_YAW, 4 Right V-Tail servo
VTAIL_OUTPUT, 2
Typicalaimster had his VTAIL_OUTPUT set to 3, but that did not work for me. I would have had to reverse the right and left tail servo connections to get that to work.
I still have to check the FBWA servo movements which might require me to check one of the "reverse" boxes for either PITCH, YAW, or ROLL.
TCIII AVD
Thomas Thank you for the help with that
@Gregory,
Take a look at this parameter file for the Anaconda
TCIII AVD
Anaconda 111514 Typicalaimster.param
