Iris 2 blinking led lights in sequence
Hi Everyone,
So I have had an Iris for a while now but never set up until yesterday. I loaded the latest firmware using APM planner, everything seemed to have succeeded.  Following instructions on Iris page I have not been successful at fully arming Iris, I keep getting two Yellow Led lights flashing in sequence. The Iris page says I should use Mission Planner to troubleshoot  (which I no longer have on new computer). I am using Mac and don't want to install any windows emulating software. I believe its not radio related because when lights are flashing and I have pressed the red button and solid, I get a long tone when trying to arm via transmitter.
My question is can... Can I troubleshoot preflight check failure using APM planner only? Or do I need to install mission planner?
I also misplaced the 3dr radio receiver, if i purchase one is there a binding process or should it be plug and play?
Thanks in advance,
Luis
  • The yellow flashing lights may just be that the flight mode is GPS enabled and requires a GPS lock before you can take off.  It depends on the flight mode.  Also if you used the default configuration and fence is turned on it needs a GPS lock before you can fly.  APM should be able to what needs to be done.
    The default configuration for the radios should be the default and should work out of the box.  Otherwise there is software to make them the same.  Don't know your location so can say what radio you need to purchase since they are no longer available at 3dr.
  • T3
    If you loaded newer firmware, you probably have to calibrate everything (compass, accelerometer) before you can fly.
    • Thanks! if thats the case can I do everything from APM planner? I don't get the mandatory hardware like mission planner, see attached Screen shot:
      3702635724?profile=original
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Saturday
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
