Hi,I currently have infront of me a very large working model of an MQ-9 Reaper. In the near future it will require an autopilot system that can direct the aircraft through a list of waypoints and on my command from the basestation follow a different list of waypoints for example, follow a circuit then on command enter a holdin pattern then enter a landing approach for me to take manual control.Will this work with Ardupilot or any other low cost systems?Thanks in advance.Jake
No, ArduPilot does not have two-way communications with the ground station (waypoints are pre-programmed on the ground). You'd be better off with Paparazzi.
