Is it possible to remove the ardupilot code from the APM2 and put on a simple arduino program - I am presuming that it should be possible, but when i try at the moment it gives me this error ...
avrdude: stk500_getsync(): not in sync: resp=0x00
which from what i read on the arduino website says that the arduino is not talking to the bootloader properly.
What I ultimately want to do is gather the raw accelerometer data and gyroscope data and see how the accelerometer in the APM (16 bit) varies from the one that i am using at the moment (10 bit).
is there an easy way to do this ?
  • Solved,
    http://diydrones.com/profiles/blogs/arduino-debugging-tips
    I had the 1280 board set instead of the 2560 board selected (point 2 on the above page).
    It is pretty easy to remove the autopilot software from the APM2 hardware and use it as a basic IMU - if someone requires it for testing.
    the basic steps are
     - compile your arduino program and upload to APM
     - run / test your own code.
     - then re-upload the firmware through the mission planner interface.
