Is there a procedure for calibrating airspeed sensor?
I'm having trouble with the airspeed sensor that I just got. When I install it according to the wiki and enable it, I get erratic flying like it's not reporting the correct air speed. With GPS it flies fine.
Is there something I need to calibrate? Is it ok to install the sensor but not enable it so I can monitor with the ground station to see if it's ok.
I'm using the config file for skywalker.
  • Does it need to be calibrated? I don't want to install it again without confirming it's working right. Can I install it and monitor it but not use it for autopilot?
