it´s possible to get ready setting-file for a EASYGLIDER ?
hello,i´m a new beginner.i will try to built a ardupilot.... i have 3 questions:# for a beginner it´s difficult tuning the parameter.can i get a ready setting-file for a EASYGLIDER ?# can i connect 2 aileron-servos to the ardupilot ?# wich GPS module is the best for ardu ?rg olli
    Hello Olli,
    Have you visited my Blog about this : http://www.diydrones.com/profiles/blogs/flying-with-ardupilot-onboard
    You will find also all the firmware v2.4.3 and the easyglider header file that I currently use successfully in flight at :
    http://code.google.com/p/ardupilotdev/downloads/list
    I hope this will help you..
    Jean-Louis
  • ahh, ok.thanks for ultra fast answer :-)
    i will order now the components...
    for what ist the ublox ADAPTER ? i need it ? or can handle the ardu-shield the ublox-gps alone (without the adapter) ?
    olli
    1) The standard easystar.h file will work for an EasyGlider, too, well enough to have successful flights our of the box. You'll probably want to tweak it for optimal performance, but that would true for any stock .h file, depending on your radio system and servo throws, etc.
    2) Through a Y connector, yes
    3) The uBlox
