I did assign channel 8 from APM2 to change the tilt servo on the camera gimbal (for quad).
I want the tilt to be change using the slider (throttle) control from joystick.It works partially...
When I move the slider, I do have only 2 position changed for tilt (up and down). I was expecting to see the tilt changing progressively as slider is moving, but not able. Any idea?
On the joystick calibration I can see the slider moving in progress. I did try 2 different joysticks, same result.
  • Nobody do have a solution? I just wanted to know if I can have "fine" adjusting of camera tilt gimbal, using the Joystick slider (throtle). When I try it, it just select 2 fixed positions.
