JSBSIM in SITL wrong version ?
I'm trying to run ArduPlane in SITL on a native debian based Linux system (Ubuntu 16.04)
In ArduCopter everything is working fine.
I followed the very good tutorial in http://ardupilot.org/dev/docs/setting-up-sitl-on-linux.html
However the intended when I run ~/ardupilot/Arduplane/sim_vehicle.py -w I get the "newer version of JSBSim"
I followed the turtorial to update jsbsim, but it say it is already the latest version.
See the terminal log :
maarten@maarten-PC:~/ardupilot/ArduPlane$ sim_vehicle.py -w
SIM_VEHICLE: Start
SIM_VEHICLE: Get JSBSim version
SIM_VEHICLE: "JSBSim" "--version"
You need the latest ArduPilot version of JSBSim installed
and in your \$PATH
Please get it from git://github.com/tridge/jsbsim.git
 See
for more details
SIM_VEHICLE: Killing tasks
maarten@maarten-PC:~/ardupilot/ArduPlane$ cd ~/jsbsim
maarten@maarten-PC:~/jsbsim$ git pull
Already up-to-date.
maarten@maarten-PC:~/jsbsim$ ./autogen.sh
--enable-libraries
**Error**: You must have `libtool' installed to compile jsbsim.
Get ftp://ftp.gnu.org/pub/gnu/libtool-1.2d.tar.gz
(or a newer version if it is available)
maarten@maarten-PC:~/jsbsim$ cd ~
maarten@maarten-PC:~$ sudo apt-get install libtool automake autoconf libexpat1-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
autoconf is already the newest version (2.69-9).
automake is already the newest version (1:1.15-4ubuntu1).
libtool is already the newest version (2.4.6-0.1).
libexpat1-dev is already the newest version (2.1.0-7ubuntu0.16.04.2).
0 upgraded, 0 newly installed, 0
to remove and 5 not upgraded.
N: Ignoring file '50unattended-upgrades.ucf-dist' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension
  • I have the same problem, and I do these steps then it's solved, works for APM code version arduplane-3.7.1
    Open the Cygwin Terminal, navigate to your home directory, and enter:
    git clone git://github.com/tridge/jsbsim.git
    cd jsbsim
    ./autogen.sh
    make
    cp src/JSBSim.exe /usr/local/bin
    Seb said:
    Hej Maarten,
    today I ran into the same problem. Could you explain the solution in more detail? I tried to research but could not figure out the solution.
    Kind regards,
    Sebastian
  • Hej Maarten,
    Kind regards,
    Sebastian
  • SOLVED
    The libtool needed an installation with -bin option
