Labview runtime : Help !!!
Hello,I need your help!Some weeks ago, I installed successfully Labview runtime.But now I cannot launch it anymore !!!I don't now how to launch it again.In "C:\Program Files\National Instruments" folder I don't see any executable file. How can I run LV ?Thanks for your help.
  • It's OK now !!!!
    I have uninstalled all FTDI drivers and reinstall Labview driver.
    In fact, the problem was the installations I made to try to read FTDI in JAVA.
    http://driver.In/
  • Hello,
    Thanks.
    I can now launch the ArduIMUDemo but it doesn't recognize the USB port.
    I try to reinstall the drivers.
  • check the antivirus ( application settings) , it some times might prevent the execution of some applications considered threat by security center( windows) , if nothing else helps , uninstall and reinstall, good luck
    You shouldn't have to launch the runtime. When you click on ArduStation.exe it automatically calls the runtime DLLs.
