Landing gear activation
Does anybody know whether it's possible to activate retractable landing gear using the barometer/GPS with Pixhawk?
I'd like to have my gear automatically switched into the down postion at say 5 metres above the ground when landing....
Thanks. DP
  • T3
    No built in functionality for altitude based deployment right now.  If you check the wiki page there are some options for mode based deployment.  I assume you are working with 'copter, anyway.
    It is also possible to DIY it, if you are ambitious.  I don't know how hard it would be to modify the firmware, I don't know a lick of it. If someone asked me to do this for work, I would use a $10 arduino mini to listen to the RC signal and to the mavlink messages for altitude in the telemetry.  From there I would implement some logic like retract the landing gear when the switch is up, but if the altitude is less than 5 then deploy them.
    Archived: Landing Gear — Copter documentation
