Laser cut custom made frames.
I have almost exclusive access to a laser cutter and so designed my own frames and tested them out
here is one of them.
If you are interested in your own fram , i can make one for £5-£10 plus material depending on its design.
Just message me
I can post worldwide
The materials i have on hand are 3mm MDF (very strong but not water proof and heavier than plywood)
Plywood (Almost identical to balsa, Stronger than MDF wight to weight, lighter than MDF but also slightly brittle like balsa)
Acrylic (heavier than MDF and more brittle, but can be many colors and transparent compare it to any toys with clear plastic, they are arcylic most likely)
