Hello all.
I've connected a Lightware SF10/c to my pixhawk serial 4/5 port as the instructions here show:http://copter.ardupilot.com/wiki/com...re-sf10-lidar/
My SonarRange is flat on 0. I can see that the unit is powered up because I can see the dot on the floor with a digital camera. I've triple checked continuity of the cable I made and I also (using the cable I made for the Pixhawk) with small jumpers stuck in the little connector, attached it to a USB to Serial adapter and with Putty I can see the distance just fine.
I dropped it down to 9600 baud, still nothing.
I'm new to pixhawk/apm world so I'm not really sure how to troubleshoot. I've double checked the wiring.
I currently am running firmware 3.3.2.
Lastly, this is still not done being built. This is my first experience with a Pixhawk. I'm upgrading from an Eagle Tree Vector. I'm not done rewiring. I am still waiting for a power module because I refuse to use the little 90A one that was supplied by 3DR.
Thank you all.
Note (may be TMI): My parts list is as follows
  • Tarot FY680 Iron Man
  • Sigma Summit Motor Mounts (~740mm now)
  • PixHawk Controller
  • Mauch 4-14S 200A Power Module (pending delivery)
  • Quanum MT 3510 630KV
  • Turnigy K-Force 30A (Opto)
  • Zippy Flightmax 8Ah 6S 30C or Venom 6s 12Ah 30C
  • 13x5.5 Carbon Props
  • 3DR uBlox GPS/Compass
  • PX4FLOW Optical Flow Sensor
  • Lightware SF10-C LIDAR Altimeter 0-100m
  • Turnigy 9XR Pro
  • Floureon 915MHz Telemetry
  • 2W 1.3GHz NTSC Video Transmitter
  • HawkEye DTF-UHF 1w 16ch
        • Sure. Let me know any progress. My copter is not complete so it's not been airborne yet but very soon it will be airborne. :-)
    • I will try this as soon as I am home from work. Thank you.
