Can anyone tell me what is going wrong here? When I try to connect to the apm and download the logs, this is the text that it starts to display. Other than the logs, I am able to connect to the apm fine for everything else.
Thanks for the help. I was unaware of the change and was using outdated instructions.
The CLI feature has been replaced with UI equivalent commands. This save FW space for APM2.5 builds and less confusion in Pixhawk builds, which has it's own CLI called nsh.
It does seem this question comes up often In APM Planner 2.0 we have removed the Terminal from a prominent view. The docs are being updated, but there are still references to the CLI.
I'd recommend using ardupilot.com docs as a base reference, as it's the most up to date docs from the dev. other sources can be out of date.
@Aaron,
Try doing it this way:Link
When in doubt, RTM.
TCIII AVD
