Logging function
Hi all,
I'm sure I missed something basic but: my copter is not saving any flight logs.  Going into the CLI in the logs function, I see that GPS PM CTUN NTUN CMD are set to log enabled, but every time I use the Log Download function it tells me "No logs."
What am I missing?
    Could be a corrupted log file. You shoud try to delete all logs.
    Did you had a crash, or did you power off the board before disarming motors ? This could have produced a log file corruption.
    I did had this problem at least two times. Perhaps you should open an issue in the issue tracker, so that eventually an automatic file recovery procedure would be implemented later.
