Hi all,
This is my first post, I looking to build my own frame from scratch, I am looking to build like the tarot iron man 5 with some heavy lifting please anyone can help me with drawings and component to fly my first machine.frame I would like to make with aluminum.
Hello! (not a guru, more like a newbie)
I am about to do the same, did you already made your frame?
I am planing to use square aluminium, I have some black coated from the local alu-shop.
And use plexiglass to join them with "pop" rivets. 500 size.
How big is the frame you are planing, motor, prop size.
APM or other platform, OSD, FPV Telemetry ....
I am wondering if I can use my CX-20 Tx, and use the modes:
GPS Hold, Return Home, Headless, and Altitude Hold.
It will be nice if you share what you are building/planing to use :-)
I am the only one flying quadcopters here in miles range.
Location La Union Philippines.
Thanks for reply, I am going to use all aluminum, would like to have frame around 500+mm, I am thinking to use 360kv motor with 40amp msc I am very confuse about using the flight control, I would like to have fully loaded FAV autopilot flight control with gps but cheap or mid range , please help me to choose flight control.
