looking for help from all gurus, to build frame.
Hi all,
         This is my first post, I looking to build my own frame from scratch,  I am looking to build like the tarot iron man 5 with some heavy lifting please anyone can help me with drawings and component to fly my first machine.frame I would like to make with aluminum.
  • Hello! (not a guru, more like a newbie)
    I am about to do the same, did you already made your frame?
    I am planing to use square aluminium, I have some black coated from the local alu-shop.
    And use plexiglass to join them with "pop" rivets. 500 size.
    How big is the frame you are planing, motor, prop size.
    APM or other platform, OSD, FPV Telemetry ....
    I am wondering if I can use my CX-20 Tx, and use the modes:
    GPS Hold, Return Home, Headless, and Altitude Hold.
    It will be nice if you share what you are building/planing to use :-)
    I am the only one flying quadcopters here in miles range.
    Location La Union Philippines.
    • Thanks for reply, I am going to use all aluminum, would like to have frame around 500+mm, I am thinking to use 360kv motor with 40amp msc I am very confuse about using the flight control, I would like to have fully loaded FAV autopilot flight control with gps but cheap or mid range , please help me to choose flight control.
Saturday
