Looking to implement ardupilot mega
Hi everyone,
just joined the forum today, as I am set on installing ardupilot mega into my aircraft but just want to try and clarify a few things before hand. As I live the UK I want to order everything I need in one go and from as fewer sites as possible as I will have to pay inport TAX and VAT.
1) Looking to purchase: ardupilot mega
                                   ardupilot mega IMU shield/oilpan Rev-H (with pins)
                                   triple axis magnetometer Rev 1.1
                                   FTDI cable
                                   Mediatek GPS
                                   A selection of cables for my desired configuration
I want to have airspeed as well so would that require 'ardupilot shield V2 (MPXV5004DP)' and if so what are the units of measurement.
Is there anything else that you would recommend?
2) I already have eagletrees system installed for FPV (http://www.dpcav.com/xcart/product.php?productid=16480&cat=263&page=1). Would it be ok to daisy chain this between the R/C rx, eagletree, ardupilot, then to the servos. Also could I use the same gps module from my FPV system to feed the ardupilot using a splitter cable.
3) what is the best option for 2-way telementry, bearing in mind that I use 2.4ghz for R/C and 900mhz for FPV (although I may need to change this as this is the same frequency that Uk mobiles work on)
Sorry for such a long post, but i'm getting confused as to how to overcome my problems.
All help much appreciated.
Mike
  • Hi Martin,
    Have been reading your posts with james regarding the Xbee 868's. If you have not already ordered them, then I would put my name down for one
  • Hi Chris,
    Thanks for your info its been very helpful. I found the list I made in my original post from the same link that you sent me. I only posted it in order to clarify what I was planning to order, as I thought I needed items that, as it turns out I didn't such as the FTDI cable - although I now see the reason for this.
    would the fact that I am operating my R/C equipment on the 2.4ghz frequency have any implications on running the telementry on the same frequency, as I have read mixed theories. Although my understanding was that 2.4ghz R/C equipment was supposed to channel hop to prevent interference.
    1) you don't need a magnetometer for an airplane or the FTDI cable at all. Also, you're confusing ArduPilotMega with the original ArduPilot (which uses that shield you mention; you don't need that with APM). If you want airspeed, get this sensor: http://store.diydrones.com/product_p/br-0004-03.htm
    2) I'm not sure about the Eagletree stuff.
    3) We normally recommend 900Mhz Xbee. In this case, you might want to switch to 2.4. Make sure you're using Xbee modules with wire or SMA antenna connectors. Don't get those 2.4 modules with the little built-in antenna pads.
    We're always trying to improve the documentation and navigation here, so it concerns me that it's not clearer what you need. Were you able to find the tabs above and the APM homepage? http://www.diydrones.com/profiles/blogs/ardupilot-mega-home-page
    If not, it would be helpful to me to understand how you came up with your list, since we should go back through that path and put in better directional signs.
  • Its for a Gas aeroplane - basically looking to do aerial photohgraphy with it
