Since updating Mission Planner (Windows) to 1.3.2 and 1.3.3 I and a number of my associates have not been able to complete Mag calibration.
The new dialogue box appears when selecting Calibrate, and it rotates in sympathy with the APM 2.5/6. But no matter for how long you work it the calibrate routine does not complete.
If you abort the Calibrate routine and check the APM2.5/6 against a real compass the two tally. APM 2.5/6 is correctly indicating the points of the compass.
This issue has only arisen since 1.3.2 onwards.
This is now fixed as of Mission Planner version 1.3.4
Thank you to the developers for getting this fixed so quickly. Awesome demonstration of Open Source benefits at work.
Could I get those with errors to test the current MP beta.
help > update beta.
and report back if it works and what your calced mag offsets are.
beta = "help" > "update beta" inside MP
ok new beta pushed again. that fixs a + vs - issue on calcing the centerpoint of the sphere.
ie it should be fixed. once someone verifys I will release a new MP normal version.
anyone feel like testing?
New install of prod version, then update under help/beta. At approx 600 samples, more data needed went away. Ran it up to 700 samples, clicked done, and new offsets are -125 -34 44.
Board is ardu 2.5
Over 7,000 data points and no joy. I stopped when my arms gave out twirling a hex! tlog attached
Parmele-2014-05-24 15-20-20.tlog
This issue is now being tracked with the developer in GitHub here --> https://github.com/diydrones/MissionPlanner/issues/475
To get flying, Uninstalled mission planner and loaded the APM Planner, mag calibrated perfectly.
can you please post a tlog. so I can see why its failing
Here attached is a tlog
This is what he did to get the log:
Had a look at post on DIYdrones and as they are asking for TLogs i thought i would grab some .
uninstalled MP -> deleted MP folder -> fresh install of MP 1.3.3 .
Started MP and selected live calibration .
Done the compass dance again much to everyone's amusement, i generated 2300 log entries and it would still not complete .
So i quit the calibration and went in search of tlogs , as it was a fresh install there was only one tlog , Its 2Mb in size , if i export it to a text file it becomes 12Mb
HTH
2014-05-24 10-21-23.zip
1
2
of 2 Next
