I calibrated the Mag with the CLI till the numbers didnt change.
When I watch the artificial horizon, the heading drifts.
Over 5 minutes the heading shifts 45 deg.
I set the declination to 6 decimal points to see if that helped.
Could this be related to the 220k resistor problem?
I havent unsoldered and removed it as yet.
Heres a hint. Dont try to configure a mag when your in a room with multiple computers and hi tech equ.
I'll check it when the temp rises above zero.
Thanks guys...
Hows this?
<code>
#ifdef IsMAG
#define MAGORIENTATION AP_COMPASS_COMPONENTS_DOWN_PINS_FORWARD // If you have soldered Magneto to IMU shield in WIki pictures shows
#define DECLINATION -13.81666
#endif
Also activated in the configurator
</code>
