Magnetometer has me scratching my head...
I have been trying to figure out why my loiter mode is circling and just plain bad compared to earlier versions of the software (I am running 2.0.49). I have been looking at the magnetometer and am seeing the following behavior (I live in Columbus, OH so have been setting the declination to -6.77).
When the quad points North the APM shows the direction as North.
When pointing South.. APM shows South.
    BUT...
When pointing East, the APM is reporting -15deg less than it should be. It should show about 90 deg and is showing 75deg.
When pointing West, APM is showing +15deg more than it should be. It should show 270 and is showing 285deg.
The following output is shown from the "compass" output in CLI:
Compass
enabled
Mag Dec: -6.7700
Mag offsets: -77.8462, -15.9017, 89.9628
Can someone offer some insight as to why I am getting these weird readings and if this is normal?
Thanks...
  • I agree those compass readings seems troublesome. But it does not explain why the loiter mode worked better in previous FW versions.
    I too am struggling with tuning the loiter out of circling tendencies, but since I am fresh on Arducopter I cannot compare to previous FW versions.
    I will follow this thread with interest.
  • Yep I found the same. Even the xbee wires need to be as far away from compass and oil pan as possible. Otherwise I found that many sensor readings become unstable. This probably seems obvious to many with more experience than myself but when I saw it for my own eyes it really hit home.
    This is certainly because you have magnetic influences on the frame. Can be caused by near wires, ferromagnetic parts.
    Near wires can cause dynamic changes, according to the current flowing in them. Lock your frame on the ground and try to push throttle and roll/pitch/yaw sticks. You shouldn't see compass deviation inside Mission Planner. If you see deviations, then your wiring must be redesigned or the compass moved far from power wiring.
    I wonder if it could be the enviroment where you're testing it.  For example if there were something pulling the compass "needle" north you'd see the behaviour you've described.
