  • Cool :) if you familiar with it then just edit the APM_Config.h in the Arduino GUI connect USB and upload the new code.
    If you have a HEXA frame, you also need to set this accordingly as well of course.
    Depending on what version you had installed before you need to go through the setup again.
    I had my mag also separately connected with a cable in fear of interference, but decided to mount it according to the wiki onto the PCB which makes it the default configuration as well.
    Ollie.
  • If you never compiled code using the Arduino and the SVN repository, I would rather suggest you mount your Compass in the default direction Components down pins forward.
    You can of course get into this, but it might be a steep learning path just to change the mag.
    Ollie.
  • Just define this in your APM_Config.h:
    #define MAG_ORIENTATION        AP_COMPASS_COMPONENTS_UP_PINS_FORWARD
