Major problems with MP 1.0.30
Michael,
I have spent a very frustrating day trying to get Planner to work with my new APM2560 board.
The board seems to be OK.  The proper sequence of lights, correct response to RC transmitter, FBW A response is correct to movement.
When I tried Simulation I got very strange results.  Sudden disconnects, Planner crashes, etc.
I took some notes:
Loaded APM 2.2.1 HIL with Planner
Did 'First Time Setup' and set Modes to Manual, FBW A, AUTO
Configuration > Loaded .param file  (Verified values)
Flight Planner > Load WP.h file  (Verified flight plan, commands)
Started X-Plane with aircraft in position > paused
Simulation > Start  (verified gains)
Planner > Flight Data "Heading to WP Home"  Set Home Alt
Un pause X-P, >  Manual take off   >  Switched to Auto  ... CRASH!
X-P > reset aircraft Location.  Reset AMP.  Getting "Warning - No data for ... sec.
Orange TX LED blinking.
I then sent you information via DIY 'Send Message" I don't know if you got it or not.
Decided to try one more time with the same results > CRASH (Simulated)
Decided to try to configure for normal flight.
Quit X-Plane  Telemaster power cycled
Restart Planner
Firmware > Connect Download APM 2.2.1
Hit 'First time' button  EEPROM erased > radio cal done > Logs cleared >
Terminal > setup > modes (Man, FBW A, Auto)  Return  > Reset APM
Verify Modes.  Exit Terminal > Configuration  Load Cadencia 07-01-11 FLIGHT.param
Write Pids >
Set ARSPD2PTCH_P Failed
Set ARSPD_FBW_MAX Failed
Set SR3_RAW_CTRL Failed
Set GND_ABS_PRESS Failed
Set PTCH2SRV_P Failed
Set GND_TEMP Failed
Set ARDPD_FBW_MIN Failed
Set SR3_RAW_SENS Failed
Set RC5_MAX Failed
Set SRD_EXTRA1 Failed
Set SR0_RC_CHAN Failed
Set RC!_MIN Failed
Set SR0_EXT_STAT Failed
Set RC4_Min Failed
Set TRIM_AUTO Failed
Set RC1_Trim Failed
Set RC7_MAX Failed
Set RC7_MIN Failed
Set TRIM_ARSPD_CM Failed
Set RLL2SRV_P Failed
Set KFF_RDDMIX Failed
Set TRIM_THROTTLE Failed
Set RC3_MIN Failed
Set RC4_Max Failed
Set SR0_POSITION Failed
Set PTCH2SRV_D Failed
Set RC8_MAX Failed
Set RC6_MAX Failed
+ 18 MORE FAILED!
What to do now??
    also does it stil lwork correctly wiht the old 1280 board?
    Could you do an manual "erase" via the cli. and "reset"
    also how are you connecting usb? or xbee?
