We are using Mapir2 NDVI camera for data collection. Currently we are using Columbus GPS V990 v2 for geotagging. We also have the trigger cable for Mapir 2 camera but not able to use it with the current GPS. Is there any way to use the Advanced GPS which is being used to trigger Mapir 3 camera with my current Mapir 2 camera ?
The official message from Mapir is that their new GPS Trigger isnt compatible for Survey 2 camera. Is there any way to make both these work together.
I have also tried searching results on using the instruments I have to accomplish but failed.Went through forum posts for my answers but it all ended up without results.
Thanks in advance
We have a GPS trigger module under beta testing for this purpose. It's developed for AgroCam NDVI cameras and for drones without the possibility of the integration between the camera and the flight controller. It's compatible with Survey 2/3 as well. It uses a UBX-G7020 receiver.
It triggers the camera based on distance calculated from flying altitude, optics specification, and overlapping, etc. It records the coordinates to file on an SD card. The file can be used in our processing app directly for geotagging the images and it's compatible with ExifTool for manual geotagging.
