In the first instance I was having erratic flying with my Quanum Nova (CX-20) and I determined to redo the Mission Planner procedure (16 steps)
I had done this earlier successfully but last week I had a crackup and I was required to replace the top and bottom shell (I smashed both motor arms).  After I had one this the quad' seemed to fly OK but nothing like before and this led me to believe that something may be electronically out of whack.
The setup went well until step 10 which is the transmitter setup.  The toggle switches would not connect for some reason so I could not set the extremities on either switch.  I pulled the battery out and disconnected it (foolishly I now discover) because the quad set up a continuous beep which I could not stop so I pulled the USB connection from underneath the quad and it stopped
Now when I connect the battery it beeps continuously and three of the motors jerk as if they were trying to start.
I feel that I have put something out and I wondered if using Mission planner I would be able to resort the original (I believe default) parameters, and if so how do I go about it?  OR as a last resort do I have to return it to the manufacturer.
Any and all help will be gratefully received and acknowledged
Regards
Ewen Bogle Hamilton Victoria Australia
