MAVlink Connection Timeout
I am pretty new at working with quadcopters and the ArduPilot software.  A couple days ago, I was able to connect to my ArduPilot completely fine (though I never was able to connect with the transmitter.  Now when I try to connect with exactly the same setup, the connection times out  I have had multiple other times where the connection just fails, and doesn't even go to timeout.  Is there anything I need to do?  I've installed the mission planner software several times and have installed the firmware many times.  I don't know how to continue troubleshooting this.  Does anyone have any suggestions?  I'm having a heck of a time with this. Thanks for your help.
  • So it turns out that Sparkfun sells the 1.0 version of this.  This might be why its not working.  They will be discontinuing the product.  Probably should buy the 3DR version.
  • Me too Listening for answers.
  • Yep Got same problem here.
    Is there a Hardware Reset ?  (aside from the obvious)
  • I would like to add one more piece of information.  Sometimes when I try to connect to the Ardupilot, it successfully goes through the timeout process and starts checking the params.  Then it will get stuck on one of them and timeout.  Don't know if this makes my problem worse or not.
