MEDIATEK GPS - bad CLI test
Hello Everybody!
I have ArdupilotMega, soldered it a few days ago and connected to PC via usb to test. Most part of the tests via CLI works good, however I've got a problem with gps test.
So, I go the CLI, then type: test - > gps and get something like this:
and this dots appear and appear in the straight line...
Could you tell me, what's the reason of this problem is?
  • Glad to hear it :)
  • I've just upload a new firmwire in the APM with new line, in which I set MTK16.
    GPS test in CLI is correct.
    Thank you very much for help!
  • Zach, signal is ok, the light comes on.
    Martin, now I use GPS_PROTOCOL_MTK in my config.h
    I was not sure about the version of my gps firmwire, so I decided not to add 16. However, maybe the problem is in it.
    I think, the version should be the latest, as I purchased my APM only a week ago.
    I will test in the evening, and than write here about the results :)
  • no signal, check the plug and check if the light comes on the gps.
