MediaTek GPS not responding with APM
Hey All,
I recently purchased the MediaTek GPS, from the DIYDrones store, for my APM board and so far have not been able to get it to respond (as in it will get gps lock but the C light on the oilpan does not light). I am running the APM  1.01 code. In the code I have GPS_PROTOCOL_MTK set. However, whenever I connect the HappyKillmore GCS it tells me that the GPS does not have a lock and the serial data displays all gps related variables as 0.
Any help would be greatly appreciated.
Thanks,
Spenser
    Hey guys - the newest MediaTek gps modules shipped from DIYDrones were shipped with a newer firmware version.  You must set your GPS_PROTOCOL to GPS_PROTOCOL_MTK16 instead of GPS_PROTOCOL_MTK,  That should solve your problem.
  • If your Blue light on the GPS is not going steady you are not getting lock.
    When I first got mine I left it for an hour and no lock
    What i did was connect my FTDI cable to the GPS and use the utility in this download http://code.google.com/p/ardupilot/downloads/detail?name=MTK_DIYdro...=
    and found I was getting a bad reception walked about and found best location and it now works fine when connected.
     Once you have a lock GPS info will come to your GCS
    If you want the number of satellites then add the following to GSC_Ardupilot tab then under the void print_position add
    SendSer(",SAT:");
    SendSer((int)GPS.num_sats);
    I add it just before the following line
    SendSerln(",***");
  • HI Spenser
    Are you getting any info on the GCS ?
    If your not then check your that you have setup GCS_PROTOCOL  as  GCS_PROTOCOL_LEGACY
    with the correct ports and Baud rates
    If you are indoors a lock may take some time then you will get data
    As standard this will not give you number on satellites or sat lock
