Hi guys, can anybody please advise on the issue below.
I am using a MT3329 gps in one of my project. The gps is connected to a serial port of my computer and I am using NMEA GPGGA interval to track the gps position change. If I move fast from a point A to a point B the gps shows position change quite accurately (say in MiniGPS app), but if I walk slowly between the same points the NMEA sentence does not show any position change at all. Is it expected behavior? Does anyone have any idea?
Thanks, Vadim.
Thank you - I spent several hours with this topic before finding this thread...
I was solving the same issue for GPS which used Mediatek MT3333 chip (Glonass+GPS) - position was freezed for slow speeds.
I realized that there is a new command for disabling the Navigation Speed threshold (working with newer chips e.g. MT3339):
$PMTK386,0*23<CR><LF>
The old command $PMTK397 is still supported by the chip, but it will not change the threshold - which is misleading.
PMTK command reference - originally for Adafruit MTK3339-based GPS:
https://www.adafruit.com/datasheets/PMTK_A11.pdf
Thank you for adding up this discussion. I had today the same problem as you and couldn't understand the reason before reading your thread. I would like to know if you tried the Navigation Speed threshold of 0 m/sec and how is it doing?
Thank you.
ACD
