Melted Connector
I accidentally melted most of the large black plug on my APM 2.5 telemetry cable. I was able to get a new plastic plug and I removed all of the tiny gold connectors (undamaged) from the mess, but I did NOT note their positions before removing them. I would appreciate it if anyone could give a description of which pin on the small white plug goes where on the large black one. A photo of yours would be great.
Thanks...Jeff
  • Here you go...
    3692536850?profile=original
    Just use the above picture and the pin-for-pin on the previously mentioned page and you should be fine. Note that one wire is skipped on the APM side, it looks to me like it is called 'CTS' on the radio side.
    -=Doug
  • I would scroll about 1/4 down THIS page. At least the red wire is clear for its location.
    A pin-to-pin picture is there. Also just above the pin-for-pin picture is the location of the black connector showing what is skipped.
    I will check the Eagle file for APM2.5 and that connector and post another response.
    -=Doug
