ROMOS from Micron, a so-called “drift-free” IMU. Image credit: Micron Digital.
Micron’s ‘Drift-Free’ IMU
According to Micron, ROMOS emits drift-free orientation and position data in millimeters to a host device or processor. Unlike conventional IMUs, additional external reference signals, such as those from GPS, are not required to compensate for drift error. Position data is generated at a high rate through internal MEMS-based inertial sensors for direct use in the host application.
According to Micron, ROMOS is able to achieve unprecedented levels of performance with “core calculations in a higher-dimensional space before dropping down to three dimensions.” Understandably, the company has remained tight-lipped when it comes to the details.
What is known, however, is that the ‘ROMOS process’ involves several steps. Raw sensor data that is generated much in the same way as any other IMU. This data then goes through primary filter algorithms, a static calibration filter and Micron’s proprietary RealMotion algorithm. Before ROMOS outputs the final position calculation, it goes through an AI smoothing function.
