MinimOSD Not displaying Certain Parameters??
Hi Yall. Firstt, thank you for being such a tight community! I am somewhat new to the Custom Drone world. I have a setup I will post specs on later, however i have a weird issue.
I have my MinimOSD hooked up, and booting. Most of the info is registering, some i still have to configure.
HOWever. Some parameters do not show up that I program through the configuration tool. (View Attached Images.  More specifically: Distance from home (top Right), the home orientation arrow (Middle above Horizon) RSSI and others.
I have tried installing every possible version of minim OSD firmware there is out there. Updated the CharSet numerous times. I am at the point where I am losing sleep! I cannot figure this out...... -.-
I know that the screen is cutoff. I believe this is normal due to the resolution of my FPV screen on the transmitter.
I am currently using MinimOSD firmware v2.2 (The extra versions of the firmware seem to have the same issue?
I am using a Pixhawk PX4 flight controller with latest firmware (3.2 i believe)
 Attached are some pictures.
Any help would be fantasmish.
3691188909?profile=original3691189015?profile=original
  • I have the exact same problem. Did you ever find a solution?
