I have problem to set up MinimOSD together with telemetry system on APM board.
  1. APM 3.0
  2. MinimOSD 0.1v
  3. Boscam Aerial camera
  4. Boscam 5.8G Diversity Receiver 7.0 Inch TFT LCD Monitor
  5. Boscam 5.8 200mw 8channels FPV Wireless Transmitter
Wiring diagram that I used:
 http://www.rcgroups.com/forums/showthread.php?t=1810347
From time to time I get short signal but suddenly it disappears. Telemetry works fine over “Y” cable.
Thanks!
Check you video output. PAL or NTSC. I had the same issue and and when I set the output of the camera to NTSC it solved my problem. Hope this helps.
