Hi Guys,
Im having problems with the new set of firmware.
I uploaded Arducopter V2.7.1 using the arduino relax, and when i use mission planner 1.2.7 to connect to it, nothing updates, all flight data does not update. It seems that the APM2 is connected to the computer, but there is no real data being uploaded.
But when i upload the firmware using the firmware tab in the mission planner, then everything works fine. I believe this is an issue with the new Mission Planner. SOMEONE PLEASE HELP!!!!!!
THANK YOU.
    If you choose to load the code via Arduino, you need to understand the APM_Config.h options and set them right. Did you, for example, uncomment this line:
    // # define CONFIG_APM_HARDWARE APM_HARDWARE_APM2
Aug 25
