Mission planner and power consumption
Hi all,
I'm using MP in combination with APM2.5 and firmware version 2.9.1.
I power my board with the 3DR APM Power Module and have voltage and current sensing enabled.
Is it possible to determine the amount of amps my quadcopter draws when hovering from a tlog file?
If so, how do I do that?
Best regards,
Henk
The Netherlands
  • 100KM
    Since you have it install and enable, the amp and voltage reading is at the HUD display in real time. When you replay a tlog you can see the reading there too.
    if you have a current sensor installed and enabled yes.
