Mission Planner - Not Responding
Can anyone help me with the new MP 1.3.9 build.
I recently got new laptop and installed MP but it just won't work, sometimes it starts but even single click on the program window gets (Not Respoding) message. Most of the time it won't even start.
Edit: I can't even kill process, only restart works.
I've got windows 7 pro 64bit installed and NET 4.5.1
  • So bad news again.
    I started MP and minimized it, surfed, youtube etc. About 1h later or so don't know excatly how much time passed. I opened MP window and it was frozen...
    I killed process and tried to run MP again, it gets frozen in loading screen. When i try to restart pc from windows laptop goes in some mode i don't know. No matter what i pres, Shut down or restart it just goes in that mode where it seems like it shut down but if i press power button only once it won't start. I need to keep it pressed for few seconds and then click again to power up..
    Anyway i rebooted and went to test if is still working as it was. I started MP and it ran fine until i connected APM via usb, went to connect mavlink and same thing again, Done! message and it gets stuck there...
    I'll try uninstalling and installing older versions later...
  • I reinstalled windows - win7 pro 64bit
    tried version 1.3.9 with .NET 4.5.3 - worked until i tried to update to 1.3.10 then it crashed(same would happen if i connect apm and hit connect)
    tried version 1.3.10 with .NET 4.5.3 - worked until i tried to connect apm
    deleted 4.5.3 and installed clean 4.0 that you linked - couldn't even start MP, got error message that i don't have v4.0 installed?
    installed 4.5.2 and managed to connect APM now via usb, tried to reproduce crash again but it worked! tried to update the arduplane fw and got error message
    [IMG]http://i62.tinypic.com/70kx3r.png[/IMG]
    restarted MP and tried to update firmware and got it working
    everything is working fine ATM, i hope it stays like this
    install .net 4.0 (it is different)
    also
    directx
    http://www.microsoft.com/en-us/download/details.aspx?id=35
    Download and Install DirectX9 End User Runtime | Install DirectX, DX9
    The Microsoft DirectX® End-User Runtime provides updates to 9.0c and previous versions of DirectX — the core Windows® technology that drives high-spe…
    • Ok, i tried to connect radio to laptop and application stopped working, had few BSODs, i tried to install new FTDI drivers. I had 2.08.30 version, then installed 2.10.0 and i got into app, clicked connect, parameters got download and it crashed on "Done" message.
    • Thank you very much, it is working now. I'll test connecting to radio when I get home.
      Cheers
