Hello, I have been successfully flying a Bixler 2 with APM 2.5 , firmware 2.74b , mission planner 1.2.90, 3dr telemetry, windows XP.
I want to use a script to set a servo but I am having problems with the following:
print " Start"
Script.SendRC ( 5 , 1500 , TRUE )
Script.sleep ( 10000)
Script.SendRC ( 5 , 1700 , TRUE )
print " End"
When the script is run, the window displays: 'Start' then 10 seconds later, 'End' but the servo does not move. I am controlling the servo fine with DO_SET_SERVO . I have also tried the first 4 servo channels. I have tried TRUE , 1 ,FALSE and 0 for the third parameter. Also Mission Planner .88 and .89.
Regards
A.E.Jones
make sure the servo options are set to pass through. normaly rc input 5 != rc output 5 unless pass through is enabled.
