Hi
I just updated my Mission planner to the latest version on an elderly win XP laptop. version 34 of MP had been working fine until the update.
After completing the update, when I try to open MP either from the shortcut or the program list I get a warning that this application is not a win32 bit application.
I have tried to delete the entire program and reload,... not better.
I tried to reload MP ver 34 this will not work either. so now I have nothing that works.
Any ideas guys.
Thank you
please update to the latest beta MP.
it will support windows xp again.
goto help > and click update beta
Thank you very much Michael!
I second the motion! XP XP XP and the crowd goes wild.
I also use it for cheap field laptops.
MP 37+ no longer support xp.
you can get the old msi here
http://firmware.ardupilot.org/Tools/MissionPlanner
XP is a x32 bit operating system, to use the latest version of MP, you need to run Windows 7, which is x64 bit version. You're better off of ditching XP...
Hi Michael
ok, I rolled this back to 1.2.99 and it still gave the same message, I deleted everything including the drivers etc. then started again and was able to load 1.2.99 and so I progessively moved forward and was able to load ver 1.3.36 and it works fine.
So I guess that this is the limit for an XP machine? This is fine, I use it only at the field.
Thaks for guiding me in the right direction.
