Mission Planner will not read my flight modes
I was recently configuring the flight modes for my FrSky Taranis Plus with Mission Planner. After setting up the switches and flight modes on my Taranis, I went to configure it with Mission Planner, but Mission Planner would not read the changes in Flight Mode. For example, if I were to flip my flight mode 2 switch, Mission Planner will not detect any change, and simply continues to highlight the original position. I have checked the PWM for each position, and they all fall under the correct spot for it. What do I need to do to fix this?
  • I tried moving a bit further away, but didn't have anything change. I am also using a flying wing, so I have the plane firmware installed. I'm not sure if I still need to assign inputs with this.
    • The problem was the Flight Mode Channel I had assigned. I needed to go under the parameters list and change the assigned channel to the channel I was using.
