Hey guys,just recently purchased a pre made arducopter and havent yet flown it. only couple days ago i installed and configure the copter with mission planner. everything went well thanks to jani's videos, however i noticed when i select the MOTOR feature to check out if the motors are working well, 1 motor on the right side of the front is making a loud noise and seems slower than the others, also when i get closer to the motor i noticed that the casing is easily coming off but the others dont do that. is this a faulty motor? i have the orange 880kv motors. im a little disappointed if it is as i havent flown it yet and just figured out how to install/config it, the copter aint cheap either :)any one can help with this?
Yep just check they look the same, and cir clip is at bottom of shaft, but with this 1 motor I can literally pull of the casing to reveal the guts of the motor, surely that's not a good thing right?
