Motor shafts
Hey,I have the 850 Kv hacker style motors for my copter, the shafts have really got bent in several crashes and although the deflection is not so clearly visible it is causing the vehicle to wobble quite a bit. I have managed to seperate the rotor and stator of the motor(and reassemble it).....there is a tiny hole near the shaft which seems to be holding it in place.....is there any way to open that up and pull the shaft out? That would make it very easy for me to straighten the shaft....I'd just have to put it into a vice and compress it. If that's not possible could someone suggest an alternative?
