Hi there,
First of all sorry if this has been answered, I've checked posts regarding issues arming the copter but I cannot find a solution.
I‘m having troubles with to arm my copter.I'm using qgroundcontrol which I've updated to the latest release and I've flashed the Pixhawk with the latest update. I've done all the calibrations. I do the test at the same room.
The copter can be armed with radio while the USB is plugged in no matter whether qgroundcontrol is runnning or not .
However, there 's something wrong when I try to arm without USB. The red light will flash 3 times and the sound just likes "mi do mi do mi do". (Safe button pressed)
Is it ok if I did't use GPS module because I just want to use it in room ? IF that is the problem , how can I
work it out?
Any ideas?
Much appreciated :)
Thanks a lot! I will try it when I get my new gps module.
