Hi there. After I set up my Arducopter I had a tilt/flip problem at take off. I followed the troubleshooting guide (calibrated the ESC and so on) but I still have the problem. I noticed that the "motors" test in CLI is not as expected. I can get only one motor to spin in test mode and only if I hold the stick up-right, down-right, down-left or up-left. the expected behaviour woul be that at lest 2 motors will spin, and then if I set the stick left, right, up, down. I tried to set to the + mode and no motor at all spins in the test mode (CLI->setup->motors). I use version 2.0.55 with a rev. 1.0 APM. In the "Setting correct prop direction" of AC2 guide someone reported the same problem, but get no answer. Any Idea?
Ok. Maybe this will help someone to give my an idea if I fried my APM and/or oilpan.
- I performed some hand tests and the IMU test. I noticed that the accelerometer values are really slow.
- During the hand test the quad still wants to compensate after a tilt attempt in leveled position.
- If I tilt the quad sideways and then back again the vales change really slow.
Did I fried soemthing? I ran into the battery voltage bug (I let the sensor cable attached during power-on for several times).
