New here and just received my RTF uDrones Quad. I downloaded Misson Planner (v1.2.38) and connected my quad over USB. I installed the firmware and connected fine.
Went out and did a test flight, basically just lifting off and sitting it down. Came back in and tried to connect again. Was told there was an update to misson planner, so I downloaded the update. Then was told that the update needed the .net 4.0 framework, so I downloaded that and installed it.
Then I tired to connect again. Loaded the firmware (not sure if this is necessary each time, is it?) Hit connect. (btw. it shows the arduino mega 2560 on comm 3, so I know the computer is seeing it). it tries to connect and then i get the following error.
I've tried downgrading to the 1.2.38 version of Misson Planner, removing the .net 4.0 framework, installing an older version of the firmware. basically everything I can think of all to no avail. Still getting this same error when I'm trying to connect.
I'm running a Macbook Pro 10.8.3 with VMware and Windows XP. This shouldnt be an issue as I was able to connect before on the same setup.
Any help would be greatly appreciated.
