Hi .. My project was about to using Odroid u3 to process vision topic from ROS then send position data to flight controller via USB port.
So i use arduino DUE as flight controller. My problem is when i transfer serial data from DUE to Odroid, barometric data sometime jump suddenly to false value (such as ~1013.00 to 345 ) .
On the other hand when i standalone DUE that issue is never happen.
I had been using my own protocal ,so it isn't false transfer problem but it from source of barometric sensor (it is my assumption).
I try in many way to filter it out but it still seem to have small jump.
Anyone have any idea will be welcome :D
#PS. Sorry for my bad eng skill
3691226880?profile=original
  • More infomation is
    when i use telemetry instend of use directly USB to transfer data this issue won't happen at all
    So maybe it cause of voltage drop while i coorperate with odroid.
    Can i put some capacitor 10uF to some place ?
